Buying 42" plasma HDTV compatible, what should I get ?
Discussion in 'Plasma TVs Forum' started by Pogue, Mar 18, 2005.
  1. Pogue
    Pogue
    Mar 16, 2005
    15
    I'm having some building work done on my house and am having a dedicated AV/HiFi room built :thumbsup:
    Now I'm not really up to speed on this sort of thing so would appreciate any help
    What I would like is an HDTV compatible plasma 42"
    DVD player/recorder with Hard drive preferably
    A good (ish)surround sound system
    A good (ish) Audio CD player (if this can be combined in the above all the better
    Not really bothered about VHS
    Will be using a SKY digital box
    PQ is very important so I would need component connectors ?
    Budget is 2-2.5k, I can wait a month or two as room is still being built so would be interesten in anything being released in the near future
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Howabout the Pioneer 435XDE or the new Panasonic TH-42PV500 out in May. Both are compatible with SkyHD and next generation HD DVD/Blu-ray. Not sure if your £2500 budget is just your plasma or the whole set-up. :confused:
    Steve
