Buying 360 bits in the US
Discussion in 'Xbox Forums' started by k3vin, Apr 26, 2007.
  1. k3vin
    k3vin
    Jan 5, 2006
    Are there any compatability issues on buying the following in the US/Canada to use on a UK Xbox 360?
    wireless adapter
    plug and play adaptor
    120Gb hard drive
    apologies if this is a repost
    Cheers :smashin:
  2. dsanders_sco
    dsanders_sco
    May 3, 2006
    173
    +6
    I think with most of the peripherals you should be okay and many take their settings from the console, e.g. the HD-DVD drive. However, you'll need to watch things like the wireless adaptor - it will work in the UK, but I believe that the US model uses extra radio channels and is *theoretically* illegal in the UK because the extra channels won't be licensed.
    Like I said, I think this is the case - but someone else might tell me I'm barking:D
    Enjoy the states, I'm out week after next - let me know if there's anything exciting to pick up.
