Bargain Buy MAGIX Fastcut Standalone Digital CD Key. £3.08p
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by JabbaNut, Sep 6, 2018.
Tags:
  1. JabbaNut
    JabbaNut
    Sep 9, 2016
    1,512
    Earth, uk
    +226
    MAGIX Fastcut contains various templates that can automatically edit your gameplay highlight footage to fit the beat of the music. Let Fastcut generate a creative trailer or montage for you, or you can manually edit your Let's Plays yourself, even if you're a complete beginner. Fastcut is the first automatic video editing software developed for fans of action.
    Video import:
    Fastcut works with most standard video clips, such as those made with FRAPS, other screen capture programs, action cams, webcams, smartphones and tablets.
    Automatic video editing:
    Video editing is now so easy anyone can do it. Fastcut automatically cuts your footage to fit the beat. Simply select an editing template with music, drag & drop to add effects, adjust colors and your montage is ready to go.
    Direct upload
    You can upload your finished videos directly to Facebook, YouTube and vimeo, or share them via Whatsapp on your smartphone.
    Custom intros, outros and text templates
    What would gaming videos be without intros & outros? Fastcut also lets you add subtitles and customize the color, font, size and speed of text transitions.
    License-free soundtracks
    Epic, dramatic or simply fantastic. Fastcut includes various soundtracks from genres such as dubstep and movie scores. All songs are available in lengths of 30 to 180 seconds and are license-free to be used for non-commercial purposes.
    Game trailers and previews for game developers
    Fastcut lets game developers quickly and easily cut together trailers and gameplay previews for their games. Commercial licenses for the included music can be obtained through catooh.com
    Video sound optimization
    Improve the sound in audio commentaries, reduce background noise and level out fluctuations in volume: Fastcut makes it easy.
    Slow motion
    Use slow motion effects to make your direct hits, stunts and spectacular explosions truly epic.
    Features
    Automatic video editing with a diverse range of action templates
    Drag & drop to apply professional video effects
    Manual mode: Switch to manual mode to edit your videos yourself
    Add titles, closing credits and other text
    Easily adjust color, contrast & saturation
    Spectacular trasitions and templates
    Video sound: Optimize audio commentary and background noise
    Change perspective: Add or remove the fisheye effect
    Image stabilization for action cam, smartphone and tablet clips
    Works with video material from all kinds of sources:
    Action cams, screen capture footage from e.g. FRAPS, webcams, SLR cameras, smartphones & tablets
    System Requirements
    OS: 64-bit systems Microsoft Windows 8.1 | 8 | 7
    Processor: Multi-core processor with 2 GHz
    Memory: 4 GB RAM
    Graphics: Onboard, minimum resolution 1024x768
    Hard Drive: 2 GB available space
    Additional Notes: Supported import formats: (DV-)AVI, MPEG-1/4, M(2)TS, MXV, MOV, WMV(HD), H.264, AVCHD | Supported export formats: MPEG-4 , WMV (HD) | Works with video material from all kinds of sources: Action cams, screen capture footage from e.g. FRAPS, webcams, SLR cameras, smartphones & tablets
    MAGIX Fastcut Standalone Digital CD Key | Buy on Kinguin
  2. JabbaNut
    JabbaNut
    Sep 9, 2016
    1,512
    Earth, uk
    +226
    Now 44p
  3. JabbaNut
    JabbaNut
    Sep 9, 2016
    1,512
    Earth, uk
    +226
  4. JabbaNut
    JabbaNut
    Sep 9, 2016
    1,512
    Earth, uk
    +226
