Buy 1 speaker or 2 (upgrade to 6.1 or 7.1)
Discussion in 'AV Receivers & Amplifiers' started by nelius, Oct 3, 2004.
  1. nelius
    nelius
    Hi All,
    I've got a Yamaha 1400 and plan to upgrade to either 6.1 or 7.1 soon. Am I going to notice any difference if there is one speaker or 2 for the rear surround effects channel or not? I can probably squeeze in both of them but it might look a little crowded. Has anyone tried with one speaker and then 2? Any noticable difference in sound?
  2. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,650
    38
    +13
    at least if you go with 7.1 it shall be very future proof like for instance blu-ray will probably end up using the latest DD technology (dd7.1)
  3. Rip
    Rip
    Aug 30, 2004
    447
    Trowbridge
    +17
    Am i right in thinking the center rear channel is just mono ?, if it is then there wont really be much diffrence in useing one speaker , especialy if you have only a little space back there. Someone please correct me if i am wrong.
