This may be a weird question, but bear with me....
I want to have my PC at the back of a cupboard completely out of sight. The only thing I want out in the room is the monitor (long VGA cable) and the keyboard/mouse/dvd (USB cables can be long as well). So far so good. But occasionally I'll need to switch the PC on or off, so I'm also going to need a power and reset button, plus ideally a power-led. Basically I need all the "stuff" at the front of the cabinet moved from the cabinet to a spot about 10 meters away (cabling neatly behind the skirting board).
Does anyone know of a UK supplier of "lose" power buttons that I can just fit with very long cables? Ideally it should all be fitted in a net plastic "box" like the ones ordinary electrical on/off switches are wall-mounted in.
Any suggestions will be greatly appreciated. Thanks.
Tomas
Tomas
