Busted Denon 500
Discussion in 'Home Cinema Buying & Building' started by Kingmob04, Feb 5, 2005.
  1. Kingmob04
    Kingmob04
    Jan 13, 2005
    26
    You have to help me.
    I came down this morning to play a DVD and for some reason the open/close button wouldn't work on the player. I noticed that some of the other buttons were also not functioning.
    (As an aside, why is it that the controller has all options under the sun, but nothing for the open/close function???).
    I looked around and noticed that the speaker above the player had lost some of the fibres from the cover- made the connection and it seems some careless sod has knocked it off and onto the player screwing something inside and making all the buttons not function.
    Does anyone know if Peter Tyson will repair this under warranty or whether Barclaycard has some kind of purchase insurance?
    I'm so upset at the moment and any help would be great??!!!
  2. TWOFISH
    TWOFISH
    Nov 24, 2004
    19
    3
    The open /close on my 500 failed after a week, It went back to superfi and they sent me a replacement player, just send it back and take a chance, they may do the same.
  3. Eallin
    Eallin
    Nov 20, 2004
    290
    Nottinghamshire
    +3
    As TWOFISH says I'd take the chance.
    Quote, "(As an aside, why is it that the controller has all options under the sun, but nothing for the open/close function???)."
    Welll...you have to get to the set to take out the disc anyway. So unless you have a remote 'put the DVD back in its case, then the cupboard' function, it's not particularly worthwhile.
    Ed.
  4. Kingmob04
    Kingmob04
    Jan 13, 2005
    26
    It is worthwhile if the open/close button is busted on the player, but I take your point.
    I spoke to Tyson and they asked me to reset the whole system, unplug everything then leave for 24 hours. I'm going to try a DVD tonight then tomorrow morning. If works on both occasions I'll leave it, but if not then it's back to Tyson.
