Buslink VPM424W-13 42" Plasma
Discussion in 'Plasma TVs Forum' started by helipilot, Dec 29, 2004.
  1. helipilot
    helipilot
    Sep 20, 2001
    319
    Hamilton
    +19
    Does anyone know anything about this panel?
    I have just spent a few hours setting one up for a friend. The instructions that came with the screen were for a different model. As far as I can tell it is an American Panel as it does not cope with a PAL-I signal. Configuring the dvd player to ntsc gives reasonable results with region 1 and region 2 dvd's.
    I have searched the net but not found anything about this particular model. I think it might be a high def panel as dvd's in source mode (unscaled) appear to be using about half the pixels available.
    I think it may be an LG panel with different electronics.
    Any ideas ?
  2. helipilot
    helipilot
    Sep 20, 2001
    319
    Hamilton
    +19
    Update :
    Have now experimented with PC input and discovered that it is not a high def panel. However it is capable of down scaling high resolutions.
