Bush VCR Help
Discussion in 'Digital TV & Video Players & Recorders' started by jamieoliver, Sep 1, 2003.
Tags:
  1. jamieoliver
    jamieoliver
    Hello all,
    I have a Bush vcr903, but the output is too close to ITV. This model does not have the old screw thing at the back to change the output signal, it is done via the LED menu on the front of the video. However I have lost my manual and cant work it out.
    Scart is not an option, as it is already taken up, so really need to change the videos output signal.
    Does anyone know how to change the signal output on this model, or a similer one. Or does anyone know what the bush website is or a contact number ???
    Thanks in advance
    Jamie Oliver (Not the naked chef)
  2. pvr_uk
    pvr_uk
    I think this model is assembled by Orion in Wales. Perhaps a manual for a similar Orion model would be easer to find?
  3. scooby do
    scooby do
    Dec 11, 2002
    2,032
    48
    +91
    Try pressing menu go to VCR setup, this is from a bush model not sure if it is the same
  4. jamieoliver
    jamieoliver
    Hi thanks for the info. I had now luck so just going to buy another one.
    Jamie Oliver
  5. avalonsatellite
    avalonsatellite
    Eject any video tape, make sure vcr is in standby, and then press and hold the power on button on vcr for about 5 secs. Press channel up or down to rf channel, then press power on button to store.
    Mat.
