Bush PDVD1000
Discussion in 'Video Streaming Boxes & Services' started by tmurphy, Sep 7, 2003.
  1. tmurphy
    tmurphy
    Mar 5, 2003
    616
    Preston
    +92
    Just got one of these little boys from Argos ( I know it's not the best, it's just to cut the bordem levels down whilst away in hotels on work!)
    Does anybody know if it can be made multi-region?
  2. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    This may work
    (from www.dvdr.eviewer.co.uk)
    Turn on the player (door closed-no DVD)
    press SET UP
    press NEXT
    press PREV
    press NEXT
    press PREV
    Use left and right cursors to change number 1 through 6 for specific region or 255 for by pass region encoding and set as REGION FREE
    press SET UP
    press SET UP
    press PLAY
    Why dont you think it is not so good ? Have you seen a review ?
    Good price for a 7" model (the others are too close to the price of a laptop !)
  3. mjwhitehouse
    mjwhitehouse
    Does this little puppy play DVD R and -RWs as I am going to the UK next week from Oz and this looks like a good deal.
  4. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    The answer is YES
    The spec is;
    7in 16:9 aspect ratio.
    Active-matrix TFT screen.
    DVD, CD, CD-R, CD-RW, MP3 playback with JPEG and Kodak.
    Picture CD compatibility.
    Subtitles and muti angle feature.
    Built-in stereo speakers and virtual surround sound effect.
    Ultra slim dimensions - only 28mm and lightweight around 800g.
    2.5 hour rechargeable lithium ion battery.
    Stereo headphone jack.
    Digital audio output.
    Colour and brightness control.
    12V car cigarette lighter adaptor supplied.
    Size (W)20,(H)3 (16.5 Open), (D)15cm
    There are a couple of clones on the market. Not sure if the mains adapter is multi voltage, and the battery is not integrated.
    Russ
  5. jordy26
    jordy26
    Can you play a ps2 slimline on this dvd player?? And where do you get the adapter from?? And where do you get the dvd player's adapter from for the cig lighter in the car??
    Please Reply A.S.A.P
    :lease:
