Bush Lcd23tv004 £399?
Discussion in 'LCD & LED LCD TVs Forum' started by akki007, May 10, 2005.
Tags:
  1. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    BUSH LCD23TV004 £399 at QED-uk.com
    • 58cm visible screen size.
    • 16:9 LCD screen with 170 degree viewing angle.
    • Resolution 1024 x 768 pixels.
    • Brightness 450cd/m2.
    • Contrast 500:1.
    • On screen menu.
    • Nicam digital stereo.
    • 2 x 5w RMS power output.
    • Auto setup.
    • Automatic search tuner.
    • Teletext.
    • UHF tuner.
    • PC input.
    • Rear AV socket.
    • Headphone socket.
    • NTSC compatible.
    • Remote control (2 x AAA batteries required - not supplied).
    • 1 SCART socket.
    • Complete with stand.
    • Wall mountable via bracket (not supplied).
    • Size with stand 43cm x 67cm x 22cm. (H x W x D)
    Does anyone have this screen? Is it worth getting? What is the response time as I cant find it mentioned anywhere on the web.
  2. macrosii
    macrosii
    Nov 13, 2004
    16
    Would not normally buy Bush but just wanted a cheap TV for on the Kitchen Wall. Should be arriving Thursday. I will try to post a review over the weekend.
    I have a Sharp 22" Aqueous and a Samsun 710MP to compare to.
  3. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
  4. macrosii
    macrosii
    Nov 13, 2004
    16
    Got TV delivered today, as promised by QED. To be honest was not expecting too much, Bush and cheap.
    First impressions out of the box.
    Not as pretty as my shart LCD TV but it seems solid and pretty well built. Controls are on the top of the TV at the back. Inputs are at both sides on the back. One side has scart, vid in, s vid in, component in and power. The other side has PC in, headphone, aud in, aud out and uhf. So the is plenty of inputs.
    So far hooked up to uhf and one of my TVs. On UHF the tunner is not bad at all on is on par with my shar aqueous. The display from my PC was clear and sharp. I just played a DVD on it via the PC and it was very good indeed. It has pic in pic so you can watch tv and play on your PC at the same time.
    Chritisisms so far. 1) Not sure if you can take the stand off which would be nice if wall mounting. 2) On Dark screens you can see a bit of light from the backlight in the corners of the screen. 3) Sound not the greatest but ok.
    Overall so far after a few hours. This is an absolute bargin, 400 quid for a 23" LCD TV and it does what it says on the box. It gets my vote.
  5. hendern88
    hendern88
    Mar 6, 2005
    52
    hi there
    whats the screen resolution is it 1280 after all
    cheers
    neil
  6. bubomb
    bubomb
    This looks a great deal. I might buy it but what is the real resolution? and what about ghosting, as I will mainly use it as a large PC monitor. Does anybody have any clues as to what the reponse time might be? Cheers.
