Bush Freeview Recorder Frozen
snowaddict
Had about 100 different programs saved on my freeview recorder and it has decided to freeze. Cannot even use it just connected tv to watch freeview through.
Anyone know of this fault. I would like to retrieve some of the programmes I had recorded off the harddrive - anyone know if this is possible. If not. Anyone know how I just get the unit up and running again. thanks for any advise.
Chris Muriel
When I saw the thread title I almost suggested you put it in your microwave oven on its defrost setting :D
It would have made sense if you had quoted the model number too.
Have a look in the PVR/VCR section (you can use the "Search this forum" tool while you're there to search for Bush or for your own model number).
Here's one thread from there that could be appropriate :
http://www.avforums.com/forums/pvrs-vcrs/1384972-bush-btu250dtr-fail.html
