Bush Freesat HD Box No Signal
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dreamsofubuntu, Jan 11, 2012.
Tags:
  1. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    I bought a Bush HD Freesat box from Argos today to replace our old sky box which works fine. however the Freesat box states there is no signal no matter what I do so I skipped ahead to enter my postcode and it found 139 TV channels which all partially work expect they skip and stutter making them unwatchable:(
    Whats going on?:lease:
  2. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
  3. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    So you think thats the mostly likely problem? I just think it's odd that the sky box works fine (I've tried the sky box after the Freesat box and it still works perfectly:suicide:) so is it because the Freesat box is more temperamental?
    either way I shall give refitting the F Connector ago, although I dont think we have any petroleum grease... or the blue peter substitue vaseline xD
  4. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,929
    Perchede 32460
    +441
    You do not need gease indoors.
  5. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    Cheers,
    Well it worked for a few minutes on BBC 1 until I decided to reset the box and get it to scan for channels again and then it did the channel stutter things again and "no signal":rolleyes: I can't work out if it was me re-jigging the cable that fixed it or leaving it the hell alone:laugh: so I've tuned it off and will leave it alone for a while and see if it sorts itself out if not then I don't know what to do:rolleyes:
  6. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    Well it worked perfectly again for about 10 minutes until I tried to access Iplayer:mad: really not impressed... after that I lost all signal and then it came back but stuttering I'm gonna phone up there CS tomorrow and find out what the problem is luckily I work for Argos so tasking it back isn't going to be a problem:rolleyes:
  7. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    My comment was based on the likelihood that changing from the Sky to the Freesat had caused some problem in the cabling and plugs, but now we know that the Sky still works the emphasis changes to the Freesat being faulty.
  8. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    I've just read somewhere that having a wireless router nearby could effect it? how likely is it that it would effect the Freesat box and not the Sky one?
    will give moving the wireless router ago anyway:rolleyes:
  9. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    Just spoke to Bush CS (really polite:thumbsdow) anyway he suggested I move the connection on the satellite to 3? and try that...
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    23,982
    Redditch
    +4,087
    That means absolutely nothing to me :confused:
    Intrigued how you are going to get up to 22000mls above the equator to change anything :D
    Best advice is dump the box (they are notoriously poor build quality and unreliable) and get a Humax Foxsat-hdr which I think Argos are selling off the smaller 320GB model.
  11. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    Did he give any indication of what he meant by that very cryptic recommendation about the satellite?
    If not, didn't you ask him?
  12. Rodders53
    Rodders53
    Dec 8, 2007
    4,845
    Bedford
    +854
    My guess:
    "Your dish requires a slight adjustment to get the best freesat signal. Adjust the $ky dish lnb skew to suit Eurobird by: loosening the lnb mounting and rotating the lnb so the pointer is on 'position 3' then re-tightening."
    it may also be a case of "Send 3s 4d. We're going to a dance"? ;)
  13. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    Ah! That explains it.
    Time to get the machine back to Argos. If they do have the Humax at sale price that's the one to go for.
  14. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    Thanks I think that's what he probably meant he was absolutely useless and there was me not understanding a word of what he said anyway:suicide:
    so is that something which is feasible? eg: me and a ladder feasible?
    and as others mentioned just getting rid and buying a Humax box would this also solve the problem? without having to fiddle with the satellite dish?
    odd thing is I came back to day and almost all the channels worked (and even Iplayer if I got to it using the red button on BBC 1) just no ITV 1:(
    silly thing I already hate it:laugh:
  15. dreamsofubuntu
    dreamsofubuntu
    Jun 3, 2010
    20
    No it's not:( I think there very careful about the pricing on them to make there own brand boxes look more appealing:rolleyes:
    Who's got the best deal at the momment on a Humax HD Freesat box? amazon have the Foxsat HD @£109 which is the cheapest I can find it new...
  16. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    23,982
    Redditch
    +4,087
    The Foxsat-HD is not a PVR, its a single tuner non recording box. You need the Foxsat-hdr (kind of assumed you would get a staff discount).
  17. logiciel
    logiciel
    Feb 2, 2008
    52,973
    UK
    +5,718
    It is, though I think it's still expensive.
    There are just six Freesat PVRs so what are these "own brand boxes"?:confused:
    freesat+ HD TV recorder - freesat
  18. lbear
    lbear
    Mar 9, 2010
    2,117
    83
    +337
    Richer Sounds have it for the same price and their 5 year refunable warranty is £11.
    Argos is £125 + £33 for a three year warranty (ie one year more than Humax give) so unless the staff discount is about 30%, there is a more obvious place to go,
