BUSH DVD142TV Region Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by LFC78, Feb 26, 2003.
  1. LFC78
    LFC78
    Can anyone help me I am looking for a region Hack for my daughters Bush DVD142TV (combi).
    I would be very greatful if someone could help me out, she has lots a R1 films and can not watch them at the moment.
  2. willylliw2
    willylliw2
    i am also looking for a region hack, if only i could get it to read the discs genuine or otherwise
  3. willylliw2
    willylliw2
    :thumbsup: re: all model dvd's .
    I have found a site which tells you the sequence that you need to enter to make your dvd region free. here is the site address http://homepage.ntlworld.com/andrew...and can not watch them at the moment.[/QUOTE]
  4. garymv
    garymv
    To convert this player to Multi-Region
    1. Press the DVD function on your TV set
    2. Press the DVD Setup button on your remote control
    3. Using your remote control, press the buttons 1, 3, 6 and 9, in order, one at a time
    4. Immediately press the Left Arrow button on your remote control three times
    5. Immediately press the Right Arrow button on your remote control once
    6. The on-screen display should now show the word VERSION
    7. Select this option and using your remote control, change it to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    To convert this player to Multi-Region if the above does not work
    2. Press the Stop button on your TV set
    3. Using your remote control, press the buttons 1, 9, 9 and 9 in order, one at a time
    4. Press the Enter button on your remote control
    5. You should now be in a secret area where you can change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
