Bush DVD-2023 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,509
    7
    167
    Birmingham, UK
    +10,235
    The player is reported to be multiregion out of the box, but if it's not, try this:
    * Press the Open button on the remote
    * Using the remote press 2, 8, 1 and 2
    * Press the Close button on the remote
    For VCD playback:
    * Put a VCD in tray and Close
    * Press the Goto button repeatedly until the VCD menu appears
    * Press Stop
    * Press the Goto button - a time bar should appear
    * Press 0 then Play
  2. steggers
    steggers
    Hope someone can help out there. I want to know if there is a firmware upgrade for the Bush 2023 dvd player. Say on the front it plays VCD/MP3/DVD etc but I cant seem to get this to work on some dvd's. If you know of a place where I can download a firmware upgrade It would be appreciated
  3. akilgohar
    akilgohar
    Thanks for the info, I need help with the same model but I still cant play any
    CD-R or CD-RW , those cds i have checked on other DVD players are working but in this DVD player they are not working could you please help us again. many thanks.
    A.Gohar
