Bush DVD-2002 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,601
    7
    167
    Birmingham, UK
    +10,463
    * Press the Open button on your remote control to open the tray.
    * Press the 7 button on your remote control.
    * Press the Enter button on your remote control.
    * Press the 7 button again on your remote control.
    * You will now enter the hidden setup page, and can change the player to any Region or set it to Region Free by entering 13 as the country code. You can also disable Macrovision from this menu.
    Or of that doesn't work, try:
    * Press Open on the Remote Control
    * Press 2, 0, 0 and 1
    * The player should now be in Multi-Region mode
