Bush DVD-1000 & DVD-2000 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,433
    7
    167
    Birmingham, UK
    +10,142
    * Open the DVD players tray.
    * Place a Region 1 disc in the tray, but don't close it.
    * Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
    * Press the Play button on either your remote or the player
    To change the player back to Region 2 only functionality:
    * Place a Region 2 disc in the tray, but don't close it.
    * Press the buttons Return and then Play on your remote control in order, one at a time
    If the multi-region hack fails to work on the Bush DVD-2000 then try:-
    * Open the tray using the button on the player fascia
    * Using the remote press 7, 7 and Enter
    * The set-up page should now be indicated
    * Change the region to 13 to make region free, MacroVision can also be disabled from this menu
