BUSH BFSAT01HD system update
socceroo
Hi everyone
Today i bought a BUSH BFSAT01HD box from argos, installed it with no problems.
An hour ago when i switched to ITV HD, the box started an automatic system software update, but since then the progress bar remains at about 10% and never moved...has anyone had a similar problem? Is this normal?
UnknownSoldier
I brought a 2nd hand bush hd receiver & setup over the weekend and was also prompted for an update, as you say it sat on the 10%'ish mark for ages, I even turned off the receiver, etc to see if this fixed the problem. Eventually I let it just sit there & it did eventually progress to update.
