Bush B320HDPVR FTP and Firmware question
Discussion in 'Freeview & YouView' started by BorgCymru, Feb 21, 2013.
  1. BorgCymru
    BorgCymru
    Dec 19, 2005
    44
    West Wales
    1: Can I ftp into this unit to add films and files to the HDD inside ?
    Where do I get the latest firmware from please?
  2. lbear
    lbear
    Mar 9, 2010
    2,117
    83
    +337
    1. Almost certainly not and 320Gb is pretty basic for an HD PVR.
    The Bush brand name is owned by Argos' parent company and their technical support should:rotfl: be able to let you know what the latest software should be and where to find any on line update. The box is probably a Vestel made one and they do not have the best record of updating firmware frequently.
  3. BorgCymru
    BorgCymru
    Dec 19, 2005
    44
    West Wales
    OK thanks. Seems a waste that you can't FTP it.
  4. Futaura
    Futaura
    Dec 17, 2008
    884
    46
    Norfolk
    +194
    You can't ftp to it, but you can telnet to it (username is root, no password). From there you can use ftpput/ftpget to transfer files on and off the box, assuming you are familiar with linux and have an FTP server installed on a local machine. It might be easier to use a USB memory stick / HDD though, via the media browser menu?
    There are two completely different versions of the B320HDPVR - internally known as the T7300 and T7650, both Vestel made. The latest publically released software for the T7650 is v1.49. Google Vestel T7650 and you may learn more :).
