Bush 3314s tune
Discussion in 'Televisions' started by ukrad, Aug 31, 2005.
  1. ukrad
    ukrad
    Hi all hope someone can help.
    I have been given a Bush 3314s portable as a backup t.v for the bedroom with no remote.
    I have got a 3 for 1 remote and it works but i am having trouble getting to the tunning in menu.
    Anyone know what button combo gets into the tunning menu?
    UKrad
  2. JayCee
    JayCee
    Jan 20, 2004
    20,088
    Lanarkshire
    +1,914
    Very rarely will a universal remote like the type you have allow you into the menu.
    Try the coloured "Fastext" buttons, they depending on the chassis fitted to your Bush may bring up the tuning menu.
    Other than that type "Bush 3314S Remote" into Google and you'll find a few UK sites selling a remote for your model.
  3. ukrad
    ukrad
    thanks for the reply. I have managed to get the colour menu up using the 3 in 1 so i was hoping to still be able to get the tunning setup menu. If anyone has the remote what button do you use to get to the tunning menu?
