Burying Cables for Plasma
Discussion in 'Plasma TVs Forum' started by kenilworth, Sep 8, 2004.
  1. kenilworth
    kenilworth
    I m very tempted to buy a plasma and mount it on my wall and then burying the cables.
    I am interested though as to whether the Scart cable from the tuner box to the screen can be purchased in a flat version, or do you have to use a standard bulky round cable normally available ?
    Any links appreciated.
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    I think either QED or IXOS do a flat scart cable that runs directly into the plug at each end rather than at an angle.
    HTH
    John
