Burnt images on LCD monitor
Discussion in 'LCD & LED LCD TVs Forum' started by monkeh, Jul 16, 2005.
Tags:
  1. monkeh
    monkeh
    Aug 13, 2004
    34
    I have been playing Battlefield 2 quite a lot recently, and have noticed, that the mini-map has left a permanent outline on my 30" medion Monitor !! :mad:
    I though this was impossible on LCD's ?
    Is there anything i can do to remove it :lease: :confused:
    I think i may have a few days left on the warranty, would they replace it for this problem ?
  2. shaddow2005
    shaddow2005
    Mar 23, 2005
    204
    OMG OMG, That cannot be possible ?
    That is one of the main advantages of a LCD over a plasma !!..
    Do you have any photos ?
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,766
    I suspect that it will clear up by itself. LCDs do not burn. But some LCD glass (Samsung IIRC) has been reported to retain an electrical charge after prolonged static images. This charge leaks away in time (don't ask how long, I don't know) and the problem leaks away with it. Try using it for something else for an hour or two. It isn't permanent.
  4. monkeh
    monkeh
    Aug 13, 2004
    34
    it been 24 hours so far, i have been playing toystory & montsters inc (most colourfull dvd i have) to see if it will clear it up. it has reduced it a little, but i still notice it on a white background :(
  5. monkeh
    monkeh
    Aug 13, 2004
    34
    here's is a picture taken now.. sorry i dont have any paint software installed, so it's a bit big. 700kb
    the camera does not pick it up very well, but you should be able to see it in the top right hand corner of the screen
  6. LV426
    LV426
    Jul 14, 2000
    13,379
    +5,766
    Yes, I see it. Patience, I think.
  7. monkeh
    monkeh
    Aug 13, 2004
    34
    Thanks Lv426, The marks have cleared up as of this morning.. Panic over :thumbsup:
    Will have to remomber to change chanels every now and then, to stop this happeneing again
