BURNT DVD-R on PC!
Discussion in 'Blu-ray & DVD Players & Recorders' started by zoro, Feb 14, 2003.
  1. zoro
    zoro
    Jan 23, 2003
    292
    I can playback on pioneer 47ai, but not on panasonic XP30? some one suggested, that they needed to be finalized? how? I use nero burning and DVDX for copying? any help?
  2. philipb
    philipb
    Mar 6, 2002
    1,985
    63
    Swindon
    +132
    Finalising is only necessary when recording on set top boxes. Unfortunately discs will not play on all players, older ones especially may not accept home made DVD-Rs.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    DVD-Rs (whether made on a PC or on a standalone), just like CD-Rs, need to be finalised before used on a player. When you burnt the disk did you check the 'finalise disk' option. If not put the disk back in and tick the finalise option.
  4. philipb
    philipb
    Mar 6, 2002
    1,985
    63
    Swindon
    +132
    Thanks Rasczak, I forgot it is an option on PC burners.
  5. zoro
    zoro
    Jan 23, 2003
    292
    Does some body use nero or dvdx for burning? back up? where is the finalizing option? how come pioneer does not need finalizing?
