BurningDVDs
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by roman700, Aug 20, 2005.
  1. roman700
    roman700
    Sep 15, 2004
    208
    +3
    I'd like to burn a DVD with some video footage. First thing's first, I need to get a DVD writer!
    Apart from that, do I need any special software? I don't think I can just copy and paste in explorer. If this is the case, can I get the software free (perhaps with a DVD burner that I buy)
    Thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Video files on your PC need to be converted to MPEG-2 to be playable on a DVD player. To do this you need dedicated DVD authoring program such as Ulead DVD MovieFactory (~£30). Many others around the same price and up are available, but Ulead is what I use and can recommend it as giving good results and being very easy to use/learn.
    Some DVD writers are supplied with software that will get you going, but the chances are it will have limited functions. You would need to pay to upgrade to the full package to get everything working or replace it with something better. IMO you are better off getting an OEM drive and buying the software that you want - could save you money in the long run!
    Mark.
  3. Greenbag
    Greenbag
    Hi eggshell,
    Jessops are selling Adobe Premier Elements 1.0 for £64.99, which is a cut down version of their award winning video editing software. According to the Jessops catalogue, it will allow you to edit your videos, add effects and transitions and also allow you to burn DVDs all from the one interface! I would also recommend Pinnacle studio v9 but see what others have said about it as not everyone is impressed with it.
  4. roman700
    roman700
    Sep 15, 2004
    208
    +3
    Thank you for the helpful replies....
