Burning VCDs
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by scott69, Apr 6, 2003.
  1. scott69
    scott69
    I have been burning projects successfully using Pinnacle Studio v8 for months now. However, all my projects are around 10 mins long and it is a waste to use a CD-RW for each one. Is there any way of getting several projects on one CD without keeping them on my hard drive until I have enough for a CDs worth?
    i.e. Can I get them from several VCDs to one VCD ?
  2. JimM
    JimM
    Jan 14, 2002
    +12
    Why not save to hard drive initially and then burn them to the Cd using something like Nero InCD, which treats the CD just like a drive. You can add projects to the CD as you want.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,752
    Somewhere in South Yorkshire
    +4,906
    If you want to make true VCDs that are playable in a DVD player - you have to burn the whole thing in one go. Multisession techniques like InCD are OK only for data CDs - not VCDs.
    So, really, your only option is to keep the source .mpg files somewhere safe until you have enough to burn a full CD.
    What you COULD do - is
    1: Make your 'temporary' (10 min) VCD onto a CDRW disc.
    2: Also, save the .mpg file onto another CDRW as a DATA disc.
    3: Repeat the above as necessary
    4: When you want to make a 'compilation' - pull the various .mpg files back onto your HDD and make a new VCD with all the files on it.
    5: Erarse all your CDRWs and start over.
