Burning stuff from sky+ box to DVD
Discussion in 'Sky Digital TV Forum' started by Katie22, Jul 14, 2004.
  1. Katie22
    Katie22
    Is it possible to connect my sky+ box to my pc and burn stuff onto DVDs?
  2. Leander
    Leander
    Mar 11, 2003
    138
    Ainsdale
    +7
    Katie,
    yes, it's possible. Think of the DVD recorder just like your VHS. You can connect, for example, scart to scart and simply use the 'Copy' function within Sky+.
    You cannot record a 5.1 DD track as there is no optical in on any DVD recorder that I'm aware of, it will only include a stereo soundtrack.
    Cheers,
    Leander
  3. Katie22
    Katie22
    Hi Leander
    Thanks for the quick response. I am sorry if I didn't explain myself very well. I don't have a dvd recorder, just a pc with a dvd burner. Can I connect up to this and copy?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    You can in theory rip the programs from the Sky+ HDD to a PC but this is technically data theft and therefore we are not allowed to discuss such things on this forum.
    A bit of internet searching should turn up a few web sites that will give you all the information you need to do it though.
    Mark.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Yes you can it's just not a simple and cheap as buying a DVD recorder unless you already have a well specced PC:)
    You need some sort of analogue capture card in the PC or a external capture device which would then use USB or Firewire to connect to the PC. Connect the SKY+ video and audio output to the capture device then record the data on the HD as raw data or as compressed data using mpeg1, mpegII (DVD spec) or other codec.
    You will also need some editing and authoring software and you will need a fast PC with a lot of ram and HD space.
  6. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Katie
    Depending on the level of quality that you are looking for you can spend from £30 for the cheapest analogue PC capture card solution, to around £600 ex vat for bit-perfect digital archiving (subject to all of the usual restrictions regarding copyright etc)
    If you need more advice then drop us a line
    regards
