Burning still images to DVD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by cliveg, Aug 16, 2004.
  1. cliveg
    cliveg
    Nov 8, 2002
    339
    Hampshire
    +8
    I have created an MPEG movie through Pinnacle Studio 7, using still images with transitions and background music. I've just realised after doing it, that I think I should have re-sized the images before I created the file to burn to DVD! :oops:
    I will be using Sonic's MyDVD to create a DVD from the movie...can someone tell me what the max size of the images should be to enable me to view best quality DVD on my TV?
    Thanks and regards,
    Clive G
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,269
    Rainham Essex
    +2,405
    AFAIK when the images were imported into Studio 7 they would have been converted to the correct size/format for displaying on a TV.
    Just create the movie in Studio with all the transitions/music etc and then author it and it should look fine on your TV.
    Mark.
