Hi - just bought and installed a Philips DVDRW824 and have successfully flashed the firmware to the latest version.
I've never burnt DVD's before though and have some files recorded using the nebula digitv card - notably Angels in America which are both over 5gb in size.
How can I burn these files to DVD as the disks are only 4.7gb each - I know that my son can record directly on his grundig standalone dvd recorder simply by selecting long play or extended play and on the back of the dvd media it gives different recording lengths according to lp/ep/slp etc. but unfortunately as far as I know this cannot be done on the p.c. - is it something which is selectable with the right authoring software and if so what software do you recommend? Or, is it selectable elsewhere or is it just not possible or is it a case of burning multiple disks and if so how do I go about that?
Hope you can help.
Many thanks
Rick
p.s. the drive comes with trial version of Sonic MyDVD and Nero 5.
Hope you can help.
Many thanks
Rick
