Burning from Itunes
Jedwards
I'm trying to burn a cd from a playlist in iTunes for the first time but I seem to be having a few problems. The 'Burn disc' option appears in the right hand corner but everytime I put in a blank disk nothing happens. I'm using Sony CD-R disks which I assumed would be fine. Could this be causing the problem, or could anyone point me in the right direction?
Many thanks!
J
L
lukey
this might sound obvious, but you do have a cd writer installed and it is working okay?
nsherin
Yep, that should work - I use Sony CD-R Audio discs for burning music CDs from iTunes with a Philips DVR1640P drive and have never had a problem.
