Burning focus/shift stabilizer, barco d 708s
Discussion in 'Projectors, Screens & Video Processors' started by jzerm, Aug 1, 2004.
  1. jzerm
    jzerm
    The focus/shift stabilizer sparks when I try to project and the last time I tried it i smelled burning, so i stopped. Is this a simple 'replace the part' solution or will that just kill the new stabilizer as well?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    They do quote comanly go. replacement is simple but you will have to readjust the G2 levels and the electronic focus.
    Don't be tempted to use the projector the arcing could get mcuh worse. :eek:
