burning dvd/cd
Gunner234
how do i burn a dvd/cd on my xp PC that will play on my Sony HXD870, will it have to be a data dvd/cd, as i want to use it in photo album, do i have to burn them in a certain speed or something. thanks in advance for any help,
Regards Gunner
StevieBuck
Yes, you will need to create a data DVD or CD.
It shouldn't really matter what speed you burn your disks at.
I believe XP has a built-in disc burning feature but there are several other programmes out there which you can use if you want to try something else. Nero is just one example.
tinytim
Try ImgBurn. It's a freeware program & clever enough to burn the CD/DVD in the correct format for what's on the disc. Best not to use the XP routine though.
