burning a dvd
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by zolapower96, Mar 30, 2005.
  1. zolapower96
    zolapower96
    hi, just finished my first project using Pinnacle 8. Burnt it to a dvd+rw, it filled 27 minutes leaving just over half an hour. I've gone to try and burn another project onto the same dvd to fill the disc up, but i get a message saying that it will over write the first project. Is there a way to burn more than 1 project to a dvd. Very grateful for any help recieved, thanks
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Once the disc has been authored & finalised no , unless you have "open" source formats such as some of the Sonic Solution products..
    You could of course combine your two projects prior to authoring & make them one bigger project & author/burn as one.
