Burn in Scare
Discussion in 'Plasma TVs Forum' started by Friction, May 5, 2005.
  1. Friction
    Friction
    Apr 20, 2004
    7
    Fell asleep last night while watching a sky+ recording on my pwd7 only to wake up 3 hours later to see the please press backup box, nearly had a heart attack as i leapt across the room to switch it off. :oops:
    As far as i can tell theres no damage, but is there a way of checking or would it be obvious to the naked eye.
  2. nak
    nak
    Dec 20, 2004
    146
    Birmingham
    +12
    Yep, it would be obvious.
    Test using a semi-bright greyscale screen. If burn-in has occurred, you will see a ghosting of the sky overlap menu.
    If you see nowt, you're okay. If that was an earlier model PW4/5 set, you'd have no chance.
    Always run in Cinema mode for run-in period (200 hrs), and you'll be okay.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The thing is nearly bullet proof, if you can't see anything in normal use it's fine. They 'age' in any case, so a very small amount of burn will diappear over time. It does not sound as if you've trashed it. My old firm left a DVD running on a 50" pioneer demo screen over a weekend once, that left SW AOTC menu on the screen all right. 3 weeks later you could not tell though.
  4. Friction
    Friction
    Apr 20, 2004
    7
    cheers guys
    Yeah definitely cant see anything just wanted some reissuance really, it would be just my luck/stupidity for something to go wrong.
    Got about 250 hrs on the clock and all settings are still on low plus wobbles on. Ill use the off timer next time :suicide: but i guess the screen is pretty resilient so no need to worry.
  5. nathanf
    nathanf
    Mar 17, 2003
    52
    :eek: :rolleyes: :eek:
  6. davegtt
    davegtt
    Dec 22, 2004
    112
    Got a panasonic Viera, we've not bought a HiFi yet so when I did the ironing (I know... dont ask) the other night and wanted to listen to a CD i played it on my PS2... if youve ever seen a PS2 playing music CDs through the telly then its got loads of icons for play, stop etc etc.... these we're ont he screen for more than an hour and nothing, second I switched NTL on it was all gone... nothing... well impressed. screen burn in? your avina giraffe!!!!
  7. alliwant
    alliwant
    this is propably a stupid question, but how do you avoid screen burn when you have an inbuilt digital tuner? dont they have logos on all the channels? My kids have cebeebies on all day?
  8. nathanf
    nathanf
    Mar 17, 2003
    52
    The tuner doesnt make a difference. Channels are broadcast tagged regardless of how they are recieved.
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes, you should get them to change channel now and then...a single logo all day is a bad idea
  10. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Especially the BBC channels, it's not so bad with the others due to the adverts every 15 mins or so.
  11. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    But not all channels lose the logo's even when showing Ads!
    On Sky the UK TV channels (e.g. UK Gold), and Discovery channels keep their logo's up through the ads.
    To be honest, its a wonder the advertisers don't complain that their expensive adverts have the channel log splashed all over them.
    In this day and age with EPG's etc... is it really necessary to have channel logo's on at all?
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    no it's not......but don't try and tell the marketing dept that! ;-)
  13. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    Now what would be cool in this digital TV age, is that as you change channels, the channel logo for that channel could be displayed for 30 seconds or so, then dissapear.
    Surely this is not beyond the present technical capabilities.
    It would certainly make the majority of home viewers a lot happier.
