"Burn-in" on LCD projectors
Discussion in 'Projectors, Screens & Video Processors' started by tomacwhite, Oct 24, 2003.
  1. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Is this possible? For example Sky channels logos, borders on movies and OSDs on games etc?
    How long would a static image have to be displayed before it got burnt in?
    I play lots of games and watch loads of DVDs etc, so would be using the projector for this. I didnt know burn-in could occur on a front projection system to be honest. Now I know its a little bit of a concern.
    Thanks.
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Not a problem, there is no easily damaged phosor as such, you could probably burn something into the panels if you left it a couple of thousand hours ;)
    --Jon
  3. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    So for example a 5 hour gaming session wouldnt cause a problem? Or a 5 hour Sky One session with that red dot wouldnt be a problem?
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    Highly improbable on DLP or LCD.
    In fact, some commentators have expressed the view that an LCD pixel that is left permanently dark for a prolonged period, might absorb heat from the lamp (especially if the internal ventilation isn't working as well as it should) and suffer heat-related damage as a consequence. I don't know of any real evidence that this occurs, however.
    I have also seen reference, in connection with some LCD panels, of an electrical capacitance issue causing a latent image to remain after the signal has gone. However, any residual electrical change will leak away in time so the effect (if it truly occurs) is only ever going to be temporary.
    Otherwise, there is no reason why there should be any long-term damage to an LCD from displaying a constantly bright image.
  5. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    Thanks for the info.
