Buring Freeview recordings (MPEG2) -> DVD ??
Discussion in 'Desktop & Laptop Computers Forum' started by probedb, Jan 4, 2004.
  1. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Does anyone have any preferred software for doing this.
    Would just be useful for archiving stuff !
    Cheer :)
    Paul.
  2. dgc
    dgc
    May 1, 2003
    216
    How are you capturing ?
    I've got the nebula card. I put the recordings through PVAStrumento to convert them from TS to PS format and then author straight to disc with TMPGEnc DVD Author.
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Nebula have said they have plans to enable straight compatability to dvd burning with future versions of their software.
    Its a great card by the way.
  4. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Same as dgc but using Ulead DVD Workshop to author. Some DVD players are able to play raw MPEG1/2 files straight from the disc, so may be worth experimenting
  5. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Brilliant :)
    Thanks all, yep, getting the Nebula card quite soon, had the Hauppauge DEC2000t but the software and hardware are not very reliable at all !
