Bumper restoration
Discussion in 'Motoring' started by Stu V, Jun 13, 2018.
Tags:
  1. Stu V
    Stu V
    Apr 22, 2007
    1,930
    +426
    D1E30287-5FA3-4271-9246-4BC3C14625B5.jpeg I’ve attached a picture of my rear bumper of my car, a BMW 3 series estate. As you can see the plastic is marked, caused by our dogs jumping in and out. I’ve run my fingernail along it and can feel no indentations or ridges so it is not actually scratched. Any suggestions as to how to restore the bumper or am I am looking at a professional repair?
  2. un1eash
    un1eash
    Nov 14, 2007
    4,978
    2
    +1,407
    If its the top of the bumper I'd whack a rear guard bumper protector on.
    • Agree Agree x 2
    • Like Like x 1
    • List
  3. Stu V
    Stu V
    Apr 22, 2007
    1,930
    +426
    Should have mentioned that I am looking to change it, hence I would like to restore it although a protector would at least cover it. Thanks
  4. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    11,973
    2
    Birmingham
    +2,330
    I would be very surprised if they’ll all come out some look unite deep.
    If you just want to “tart” it up and make it look better something like poor boys black hole contains fillers and will cover quite a few of the scratches as a temporary measure.
    If you want something a little more permanent then a decent polish with cutting pad will be required - there are hundreds of options to choose
    For an even better job a wet sand and polish would remove a good 90/95% of those marks but would most likely require a pro to do it for you
    A machine polisher with a 3” pad would do a much better job than trying to do it by hand but again might not be something easy to come by if you don’t have one! You can apply the poor boys by hand but it’ll take a little work for it to work it’s best!
  5. IronGiant
    IronGiant
    Jun 7, 2003
    65,140
    +44,809
