Quantcast
bullet proof monk 2.99 Wollies.
P
pointsofview
Hi there, sorry to sound pernicky... is Bullet Proof Monk 2 disc?
PS It's cheap either way. :)
P
pointsofview
:lesson: Sorry, I didn't read it exactly as stated. D'oh!
Thanks for replying, I'll check it out.
M
malcy
The UK is only 1 disk.
It is missing the 2nd commentary (by the writers) which is on R1, otherwise the same.
The 2 disk version is the HK R3 which is very cheap. Has DTS track & extras on 2nd disk (however misses both the commentaries).
JAMESTALKALOT
Also you will find The Matrix for £2.99, Matrix Revisited also £2.99. Willy Wonka and the Chocolate Factory £2.99 (I bought this:D )
There's about 20 odd titles from £1.99 to £4.99 with some good ones in there.:smashin:
EDIT: this as far as I know is in store only. Woolies website has Willy Wonka down at £10.99
