Bulkpaq Green X2 DVD-R - what are they like
Discussion in 'Desktop & Laptop Computers Forum' started by pete18, Oct 1, 2003.
  1. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    I want to order these and wonder what thay are like quality wise
    I have seen them on big pockets , i was using there own brand which have been very good just want to try a different media.
    i have a panasonic 310 dvd writer
    cheers from pete
  2. sc1977
    sc1977
    Jul 16, 2002
    616
    kent
    +8
    bought bulkpack cdr media what can i say but to put it mildly
    THESE ARE A BUNCH OF CRAP
    still got about 78 left as i wont use them now
    disks are aparently rated at 48 speed but nero picks them up at all different max speeds some even as low as 12 speed
    if i successfully write a disc it only works in the drive it was written on, i dont know if i have a bad batch but i wont be using them again. As for bigpockets own media ive had 2 lots of 100 cdrs and they were great so stick with them if i were u :lesson:
    regards
    stu:smashin:
  3. TEK
    TEK
    Good old Bulkpaq... another batch... yet another dye :)
    Personally I stay clear of Bulkpaq as I find their reliability too inconsistent, even on a Ritek dye. If they're Princo then avoid like the plague. These however are Prodisc ?!?!
    http://www.disqworld.net/forums/viewtopic.php?t=45205&highlight=bulkpaq+green+prodisc
    I'd keep an eye on that thread if I were you and wait for a few other opinions before buying or play safe and just go for a trusted brand that uses Ritek as they've been proven time and time again
    Cheap isn't alway cheerful
  4. pete18
    pete18
    Apr 14, 2002
    1,084
    41
    Torquay
    +3
    cheers for the heads up
    i'll order some more big pockets own brand as they have been good,
    for the time
    cheers from pete
