bulb question
Discussion in 'Projectors, Screens & Video Processors' started by andya, Oct 14, 2004.
  1. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    if i get a bulb for the sony h20 from the states will it work with my uk model.its just that i can get them from usa much cheaper than here
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    If the part numbers are the same then there should be no problem - I know that at least one member here got a replacement lamp from Pricejapan - they should all be the same.
    S.
