Bulb Life
Discussion in 'Projectors, Screens & Video Processors' started by purplesticky, Mar 17, 2005.
  1. purplesticky
    purplesticky
    May 11, 2003
    61
    Im pretty new to projection and i just recently bought my self a Infocus Litepro 620 projector which im having alot of fun with.
    I bought this projector secondhand and the guy i bought it off didnt no how long the bulb had left in it.
    i was wondering is there any way i can check the bulb life or what sign should i look out for to know when it's on it's way out at the mo it's seems fine.
  2. ptek
    ptek
    Usually, menu will show runtime, but to check, goto Infocus site in the states drop down list to select model, they have faq's/user manual, etc
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Many projectors allow you to reset the bulb life counter whether you change the bulb or not.
    I suppose it's akin to clocking a car really, and I can't believe it doesn't happen to some extent on the 2nd hand market.
    Any ads that say "new bulb just fitted", take it with a pinch of salt unless backed up with a genuine looking receipt...PJ
  4. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    Beats me why the manufacturer's make it so easy for you to reset the counter. The thing should somehow 'know' when the bulb has been replaced... or is that a bit unrealistic with current technolgies maybe :confused:
  5. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Not at all. When you are paying between £150-£500 for a lamp, there is plenty of opportunity for them to integrate a small eeprom into the lamp assembly that can track the hours used. If third party printer cartirdge manufacturers can afford to put a simmilar device in a cartridge selling for under a fiver the PJ manufacturers have no excuse.
  6. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    Some projectors have a non-resettable counter which counts the number of lamp-counter resets and/or a non-resettable total power-on hours counter! (non-resettable by the average user that is)
    Neither of course can tell you precisely how many hours are on a specific lamp (after all, for one thing there's no way to tell if the lamp was new or not when first installed), but eg if a projector/lamp has a claimed 700 hours on it and has had half a dozen lamp-counter resets, the alarm bells should ring for most people.
    The problem with an eeprom would most likely be heat - there's also no way to be sure that the eeprom itself had not been reset!
