Bulb for a ptae 2000
Discussion in 'Projectors, Screens & Video Processors' started by dUnKle, Mar 5, 2013.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
    My projector has little over a thousand hours of it now and have noticed when watching a film the brightness fluctuates up and down so guess new bulb needed
    Anyone know of a reputable and value for money supplier.
  2. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    The part number for an original bulb is ET-LAE1000 and you can buy direct from Panasonic UK here: https://www.pas-europe.com/ for £216 + £4.32 postage.
    Considering the cost price on one of those is £180+VAT to a dealer (I know because I just logged in to my spares ordering system) Looks like Panasonic are just offering these out now at trade price.
    If you use that part number in google, you will get results for copycat bulbs.
    Good luck :smashin:
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
    Are third party bulbs worth it
    Seventy five quid on eBay
    220 is probably a good whack twds a newer equally as good pj
  4. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    Never had any experience with any 3rd party bulbs, so can't help there.
    I have no idea what you're saying in that last sentence, are you using predictive text on a mobile?
  5. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    :laugh:
  6. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
    Sorry. Yes
    Was just thinking that I imagine that the price of a new bulb is probably now a sizeable chunk twds a brand new projector which would give my gaining on a run for its money.
  7. chienmetallique
    chienmetallique
    Mar 3, 2009
    1,165
    +184
    Bulb fluctuation could be down to using eco mode from new, try using normal for 10-15 hours.
  8. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
    It's doing it in normal also now. Mind only run it on normal for couple hours or so so will keep,it like that for few more movies then try revert back.
  9. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,062
    +7,991
    Might take more than a few hours: My old AE2000 did this and it took 30 hours plus IIRC (I usually ran it in eco so 30 hours in normal to clear it).
    Another thing to check is that it is the lamp and not the iris playing up: Put up a full field test pattern maybe 75% white and see if this flickers. If a static pattern flickers then it is likely to be the lamp (or it's power supply). If it only flickers during normal film viewing it could just be the iris. Though I do think the lamp is more likely it's easy enough to check otherwise that's £200 towards a newer projector if it's not the lamp.
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
  11. Timh
    Timh
    Sep 14, 2000
    5,272
    3
    3
    Altair-4
    +342
    I purchased a new lamp direct from Panasonic for my ptae2000 and I was surprised how dull my old lamp was compared to the new one.
    Be aware though that when mine arrived it came with a receipt but no info reguarding warranty .
  12. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,652
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +682
    Have you tried reseating the lamp?
    This is also so true. It's amazing what you get used to.
    I've seem it so many times.
    Regards, Shane.
  13. dUnKle
    dUnKle
    Jan 1, 2001
    15,891
    +2,888
    Cheers guys
    I may just wait for the existing one to go POP
    The PJ is probably only used these days couple times a month
