Bulb failing overnight
Discussion in 'Projectors, Screens & Video Processors' started by chilly, Jan 9, 2008.
  1. chilly
    chilly
    Hi all
    I have a three year old Hitachi PJ-TX10 with only 160 hours on the lamp, this is the lamp that was supplied from new, the lamp has almost gone from full brightness to virtually no brightness overnight, the unit is ceiling mounted on an LMP mount and is always covered in a room used very litttle, the unit is never subject to any dust and has never been shut down incorectly, am I right to assume that the bulb has gone after such a short time or should I look elsewhere, also would the fact that I have had the PJ for 3 years contribute in any way (ie, does the bulb wear over time), thanks for any help.
