bulb alignment
J
jimmyj
Alright guys,
I have a 60ish inch rear projection screen that used to be part of a virtua cop arcade machine (see attachment) and in transporting it from one room to another the bulb alignment has become corrupted - there are 50ish twist switches that control the alignment but they are not labled well and i cant make head nor tail of them, i have also tried trial and error but that isnt working.
Can anyone help please ?
Many Thanks
C
Chumpy
You are best off checking perhaps either a coin-op site (maybe you have a coin-op operator nearby?) or the news groups under rec.games..... Usually a site or newsgroup reader will be able to help you out.
