built in panel speaker suggestion
Discussion in 'Home Cinema Speakers' started by bisher, Jul 15, 2005.
  1. bisher
    bisher
    May 15, 2004
    91
    +3
    hi all
    i am going to build a panel under my plasma to hide the cables rather than channel the wall. it will be about 100mm from the wall .
    what i want to do is put 2 speakers in the panel instead of buying the manufactures models that fix to the side of the plasma.
    can anybody recommend a set that will fit in such a small depth and have a good all round sound . i don't have a million pounds to spend so a budget of £150.00 is probably my limit.
    many thanks for any help
    bisher
  2. Troon
    Troon
    Apr 28, 2005
    151
    Unless you're misguidedly trying to achieve stereo reproduction with such a small separation, the best thing to do would be to get a high quality centre speaker. Hifibitz has a good selection of centres: I'd particularly look at the AE Evo Centre, the Mission M3C2i and the Monitor Audio SLCR.
    However, if you eventually get a proper surround setup, you'll want to match your centre with your L/R front speakers - something else to consider...
    If you're really stuck for depth, look at some in-wall speakers instead.
    I have no affiliation with HiFiBitz: I've used them a couple of times, but the main reason for the links is that their site has a convenient listing format.
  3. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
