Built in Freeview on the LE32R74BD....
Discussion in 'Freeview & YouView' started by badlydrunkboy, May 5, 2007.
  1. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I'm having real issues with the built in freeview on my tele. Its keeps going really pixelated and makes a horrible, almost scratching noise. Has anyone else had this problem? It mainly seems to be on BBC channels which i find odd.
    Any help would be great. Cheers :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    23,755
    Lanarkshire
    +2,569
    A poor signal is the usual cause of those symptoms.
  3. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    Without trying to sound a bit simple, how do i improve the signal? Barring in mind I live at the parents still.
  4. JayCee
    JayCee
    Jan 20, 2004
    23,755
    Lanarkshire
    +2,569
    Do you have the built-in "LNA" (Low Noise Amplifier) switched on?...page 11 of the user manual.
  5. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I have no idea. should i have? What does it do?
  6. JayCee
    JayCee
    Jan 20, 2004
    23,755
    Lanarkshire
    +2,569
    It boosts weak signals.
    Read page 11 of the user manual and it will show you how to switch it on...if it isn't already.
  7. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    Just had a go and for some reason, when I'm on digital TV it wont let me select the channel option from the menu, so I can't get to the LNA option.
  8. JayCee
    JayCee
    Jan 20, 2004
    23,755
    Lanarkshire
    +2,569
    I think it can only be switched on within the analogue channel menu...but once it's on it boosts both...not too sure but you have nothing to lose.
  9. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    I went into the service menu and it looks like that is already on.
  10. JayCee
    JayCee
    Jan 20, 2004
    23,755
    Lanarkshire
    +2,569
    That isn't the "service menu"...at least I hope you aren't in there :thumbsdow...that's just the "Channel" installation menu.
    It may have been switched by whoever installed it...if you are having reception problems on the Freeview channels your only recourse is to get your aerial system checked out.
  11. aekostas
    aekostas
    Jan 2, 2006
    1,263
    48
    +52
    Try switching it off; you may have too strong a signal, which causes similar efffects.
  12. dibdab
    dibdab
    Apr 29, 2005
    1,374
    Kent
    +108
    What kind of siganl strength reading out of a 100 are you getting for say bbc1, mine is around 60 with the bit rate error flicking between 0-1 and it's a good picture.
    It is in the dtv menu, i think it's that button. Not at home at the monment so not a 100% sure.
  13. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    How do i see what signal strength im getting?
  14. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    838
    +38
    go into the digital menu and - a button on the righ hand side of the remote.
    select the bottom option - and then there is an option for the signal strength.
    sorry for the vague details - doing it from memory
  15. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    Signal strength seems to be anywhere between 15 and 30. That aint good is it! Does that mean its a problem with the aerial?
  16. dibdab
    dibdab
    Apr 29, 2005
    1,374
    Kent
    +108
    Yea that signal strenght won't get a good picture. Check all the channels as they will all have a different strength. Did you get bit rate errors aswell?
  17. badlydrunkboy
    badlydrunkboy
    May 5, 2007
    140
    16
    yeah, bit rate error was about 5 i think.
