Built in Freeview on samsung LE32R74BD
Discussion in 'Freeview & YouView' started by diddy6662002, Jan 21, 2008.
  1. diddy6662002
    diddy6662002
    Jan 2, 2008
    108
    As above I have this TV which apparently has built in freeview but I cannot find it anywhere. Even the manual is flimbsy with wording and does not even mention the word free view. Can anyone help me
  2. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    you should see the DVB logo on both the set and the manual. Normally samsungs have a button labled tv/DTV on the remote. Can't remeber this exact model but i'm sure it was digital. TRY page 21 of 39 in your manual.
  3. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    I've been trying to check the Samsung website but "We are sorry, we are currently upgrading our servers and the website you requested is unavailable." - so I'll try later.
    However, although Freeview may not be mentioned it will probably be referred to as DTV (Digital TV) and analogue may be referred to as ATV.
    The menu will have an option of scanning for DTV channels which is what you're trying to do
