Building my own PVR...
Discussion in 'Digital TV & Video Players & Recorders' started by pix, Nov 2, 2004.
Tags:
  1. pix
    pix
    Mar 17, 2004
    10
    Hi all.
    I've decided than none of the off-the-shelf PVRs I've seen will do all I want (or in the way that I want), so I'm going to build my own. I've written an article about it, and I'd be interested to hear any comments you might have. Mainly, have I missed out anything important!
    Thanks.
  2. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    Have you looked at getting a PC running Microsoft media centre 2005 - it sounds like it will do most of what you want... recording programs based on key words etc...
    Have a look on MS site for more.
    Reg
  3. pix
    pix
    Mar 17, 2004
    10
    I have a copy to try out (we are a system builder), but I wont be able to put together a complete system including license for £400 quid - it requires quite hefty hardware.
  4. macta
    macta
    You know - I've come to the same conclusion...
    I'm pretty sure that I can do the software - its just picking out the hardware - bearing in mind it has to be quiet!
    I'm also a bit confused about how you hook up said device reliably to a wide screen TV, and how you get good audio output too.
    The digiMatrix box looked good - but its micro pci slots rule out freeview tv cards, the Asus Pundit looks good - but is it quiet enough (and will it dish out decent quality audio and video).
    Its quite a mine field but I'm interested in comparing notes.
    Too really keep the price down you may have to ditch windows - so maybe use Linux or potentially just use a raw VM on the hardware (squeek os might be good or kaffe?)
    Tim
  5. Teapot
    Teapot
    Oct 9, 2004
    11
    Check out MythTV It does most of what you want, at a price. You need some Linux expertise though.
    OR
    How about taking a Thomson DHD4000, stick it in a nicer case with a 120Gbyte hard drive and the usual quiet PC mods.
  6. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    If you want near silence, you will have to go for passive water cooling or a VIA Epia based system. The Epia's are not high powered in the sense of a AMD 64 but have hardware dvd decoding built in and have a very small form factor. The CN400 chipset has Mpeg2 and 4 acceleration, DVI output and HDTV support as well.
  7. pix
    pix
    Mar 17, 2004
    10
    I am looking at the EPIA kit, but I will need 2 PCI slots for 2 Freeview tuners, so I'm trying to work out what will cope.
    Does anyone here have any EPIA kit?
  8. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    I take it you are including all your man hours it takes you to write you own software in the total cost....? I got a media centre PC for £699 from PC world with 17in tft so minus monitor would work out not much more......
    Why re-invent the wheel? :confused:
  9. Teapot
    Teapot
    Oct 9, 2004
    11
    2 slot riser card
    http://www.mini-itx.com/store/?c=8#p1902
    I have used Mini-ITX boards to run MythTV. It's a bit pricey if you buy the fancy cases, but the boards themselves aren't bad.
  10. Teapot
    Teapot
    Oct 9, 2004
    11
    OK I'm a Linux bigot. I bought a Windows Media Centre PC for evaluation, I don't think it's quite there yet. But i agree with you 110%, Windows OR Linux, why re-invent the wheel?
    I'd recommend a Thomson DHD 4000 for PVR, it has two tuners for 159 quid, I own one, and a Mini-ITX for MP3s and photo with MythTV (or WinXP if you like). Then you can use a nice low-end Mini-ITX and be happy, 'cos tuner PCI cards cost much money.
  11. Teapot
    Teapot
    Oct 9, 2004
    11
    I've built a Mini-ITX that is near perfectly quiet.
    Change the CPU heatsink and ditch the fan. Stick a Zalman motherboard heatsink on the CPU.
    http://www.quietpc.com/uk/vgamb.php#zmnbj
    More importantly, if you use a Seagate drive with cover plates top and bottom, stuff it in one of these and you hear nothing.
    http://www.quietpc.com/uk/harddrive.php#silentdrive
    I put this together at work in February and ran it 24/7 till June, no noise and it didn't die on me.
  12. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    That's a bit pedantic, you can make a Athlon FX55 silent if you are prepared to add the appropriate bits.
  13. pix
    pix
    Mar 17, 2004
    10
    Thanks Teapot - I am certainly considering MythTV as I'm happy to fiddle about with stuff if I can end up with just what I want. I've found supported Freeview tuners on ebay (new OEM) for around £35, so the cost of them isn't a problem. Mind you, if I could find a supported twin tuner PCI card, all the better.
  14. Teapot
    Teapot
    Oct 9, 2004
    11
    That's a good price. Got a URL or a model number? I want to get into MPEG editing so something like that to experiment with would be very nice at 35 quid!
  15. Teapot
    Teapot
    Oct 9, 2004
    11
    Huh? What's wrong with posting a couple URLs? No offence taken or intended, just curious about "pedantic".
  16. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    Teapot
    In my first comment, I didn't think it necessary to give a description of how to make a system silent, the words 'near silent' were enough, describing how was where the pedantry came in. No offence intended either. :)
