Building my new computer, system suggestion please £300 - £500 budget
Discussion in 'Desktop & Laptop Computers Forum' started by TurnipFarmer, Sep 18, 2007.
  1. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    I am thinking about building a new system as my current system is getting a bit old.
    Is building still the way to go rather than buying as I built my last one and saved quite a bit.
    Could you guys suggest some systems in the £300 - £500 range please
  2. Dodgexander
    Dodgexander
    May 29, 2007
    14,654
    +4,314
    We cant really reccomend unless you tell us what you want your pc for.
  3. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,259
    38
    Hertfordshire
    +5
    Use it mainly for internet, sometimes word processing, I want to be able to play more games, listen to mp3s, ummmm thats all I can think of at the moment.
  4. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
  5. devil666
    devil666
    hi razor .. i am thinking of building a budget gaming pc ..do you think this spec is ok and compatable ~
    cpu
    http://www.ebuyer.com/UK/product/130484
    mobo
    http://www.overclockers.co.uk/showproduct.php?prodid=MB-003-EA&tool=3
    ram
    http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC&groupid=701&catid=8&subcat=813
    graphics
    http://www.overclockers.co.uk/showproduct.php?prodid=GX-113-AS
    i would be grateful if you could advise me if this is compatable and a decent set up .. could you also recomend a good psu... thanks for any help , have not built one before so brickin it.
  6. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Thats the same as what i have posted above apart from a different brand of graphics card. It will be fine.
    As for a psu I can recommend either one of these.
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-CS&groupid=701&catid=123&subcat=823
    or
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-CS&groupid=701&catid=123&subcat=823
    A 450 watt will work fine with the above spec.
    Building is easy, just take your time, read the mobo manual. :)
  7. devil666
    devil666
    thanks razor.:clap: gonna overclock it so might be askin a few more questions . lol .. any good web sites about overclocking this board and cpu ..thanks again let you know how i get on ....:thumbsup:
  8. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    You can use the guide on overclockers but there is another one I have on my other pc. I will try and post it up later,
    C2D are very easy to overclock. :)
  9. booyaka
    booyaka
    Sep 26, 2002
    11,050
    +3,576
    http://forums.overclockers.co.uk/showthread.php?t=17612922
    is a good starting point.
  10. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
  11. devil666
    devil666
    thanks guys :thumbsup:
