Building Black Gold BGT3xxx DVB-T2 Drivers for Linux
robbo100
at the moment i can not test, but next week i will try to have a look unless someone else say
some time linux keep you in it own directory so you could try cd / then do ls to see if it give you the whole file system
if it does not then you do not have root access so you never see the / directory
cd / worked! Nice one. I don't know why I didn't try that before.
I have now have a directory /usr, but there is no /usr/src directory
robbo100
Ah, a bit of googling shows that /usr/src is an optional directory, so I decided to make one myself. Unfortunately the /usr area is a read-only file system, so I can't add a directory
trident01
mkdir /usr/src
cd /usr/src
if it allows you
opp missed what you said
you may need to learn chmod to change permission like chmod 664 but dont do 777 even thought you can it very dangerous
or see if sudo mkdir /usr/src works
johnandally
Hi there.
Thought I'd have a go at getting my Blackgold card working in Ubuntu after my machine has started to struggle in Win 10!
I've seen trident01 has had some success and had very helpfully supplied a git hub to his build packages.
It seems to have been down for a while? Is there any other way I can get access to the drivers and your package?
(Am using
sudo git clone http://www.cblinux.co.uk:5010/BGT3xxx
Much appreciated
Many thanks
John
trident01
not done much on it for a long time as i've been very sick
and i dont get any help on the bug the code has so am sorry if more bug have come in
please say what not working and i try to fix
johnandally
Many thanks trident01 - that was quick!
Sorry to hear of your illness. Hope things improve soon.
I've 'git cloned' successfully and will try the sh early next week.
Thanks again
John
Blackmyre
Hi, I have a BlackGold BGT3620 card that I want to try using under Linux. I gather that this would involve building the driver myself from source - not something I've tried before, but willing to try and I came across this thread while reading about it. I seem to be falling at the first hurdle though:
fatal: unable to access 'http://www.cblinux.co.uk:5010/BGT3xxx/': Failed to connect to www.cblinux.co.uk port 5010: No route to host
Is the repository available anywhere else that I could try, such as github or something?
m10dos
Has anyone one got a copy of these linux drivers that trident01 supplied as the links are all down.
Any help would be most appreciated.
Phil
trident01
sorry my fault will have it fixed today
was doing stuff on my server as i had to change the storage box
so it my fault as i thought it was up
m10dos
Hi trident01
Many thanks for your very quick response. I so glad you've spent time updating/developing the Black Gold drivers.
Kind regrads
Phil
trident01
not done anything on this for a long time so sorry if it not working on new linux
if people do find problem and can say i try to look into it soon
DragonQ
I've spent a few hours today modifying the source to be compatible with Linux kernel 5.4, which is included in Ubuntu Server 20.04 LTS. I've managed to get it building but cannot test it yet. I plan to borrow one of the two tuner cards in my main server and put it in a test rig to try this out, but I'm not sure when I'll have time to do that. :)
tumbleclatter
if you got this to build, I'd be interested in giving it a go. I have a machine with a card in that I can boot from a live usb stick and build the module. I tried to build this source against the ubuntu 20.04 5.4 kernel at the weekend and was saddened at my inability to fix even the implicit definition of i2c_somethingorother issue that I was getting.
DragonQ
Cherry-picking this commit should be all you need. I'm currently running this build using kernel 4.15 and it seems to be working. I can build it on kernel 5.4 but I haven't tested if it works yet.
Latest News
What's new on Netflix UK for November 2021
  • By Andy Bassett
  • Published
PrimaLuna debuts Evo 300 Hybrid integrated amplifier
  • By Andy Bassett
  • Published
Astell&Kern announces AK ZERO1 in ear monitor
  • By Andy Bassett
  • Published
McIntosh launches MI1250 power amplifier
  • By Andy Bassett
  • Published
AVForums Podcast: 13th October 2021
  • By Phil Hinton
  • Published
