Apone
I have a 5ft wide brick chimney breast which i want to attach a flat panel on. I also want to then build a false wall 'around' the flat panel so it appears flush.
The plan is that my centre speaker will be mounted inside the chimney breast which will mean i get a hole big enough to house it. I would like the front of the centre speaker to also be flush with the false wall that will surround the TV.
Current kit consists of 3 X MK S150 LCR speakers. My centre MK is the square box version. I have toyed with the idea of inwall or onwall MK S150 to replace the centre but as i already have a speaker, i am thinking it would be a waste to not use it. My concern is the affect of putting the speaker in a chimney breast will have on the sound.
I know THX reccommend a speaker baffle wall in theatres, this ensures the sound is projected 'int'o the theatre, so this logic seems good to me for home cinema as well.
Any ideas plesase on what i would need to build a good baffle wall that would go around the centre speaker and what materials i would need please?
