lmccauley
Building a Raspberry Pi Squeezebox Player for £100
Introduction
A few years ago, I decided I wanted to be able to access all my music around the house. I looked at the options, and liked the look of the Logitech Radio and Touch devices, and Media Server software – originally known as Squeezebox. So, I ripped all my CDs as FLAC and stored them on a RAID5 array on a HP Microserver, installed Logitech Media Server (LMS) and bought a couple of Logitech Radios. I also downloaded the Orange Squeeze app for my Android phone, and used that most of the time to control the radios. This worked great, but when I looked for a Touch to plug into my main hi-fi I discovered that Logitech had discontinued the whole line. Recently, I’d been looking again at options for a streamer to plug into my hi-fi, and I discovered SqueezePlug & Max2Play software for the Raspberry Pi, and a high quality DAC made by Iqaudio. They also made a case, which I thought looked smart.
Assumptions
From Amazon (£43.38):
Instructions
Download the NOOBS-Image of SqueezePlug & Max2Play for the Raspberry Pi from Download the Max2Play Image for Raspberry Pi and Odroid | Max2Play
Follow the INSTRUCTIONS-README.txt file to install the image onto your SD micro card.
Insert the SD card into the Raspberry Pi.
Download the instructions on fitting the Pi-DAC+ card to the Raspberry Pi from http://www.iqaudio.com/downloads/IQaudIO.pdf
Attach the Pi-DAC+ card to the Raspberry Pi.
Note – use the 4 x 5mm PCB standoffs from the Pi-CASE+ instead of the screws supplied with the Pi-DAC+ for the bottom of the Raspberry Pi.
Plug the Raspberry Pi into a monitor using HDMI. You shouldn’t need to use a keyboard. You don’t strictly need the monitor, but it’s nice to see the progress on screen.
Connect the power supply.
Wait for it to load – about 20 minutes.
From a PC on the same network, go to http://max2play. You can make a number of config changes from this web page, including enabling/disabling the Squeeze player, and rebooting the Raspberry Pi.
Shutdown the Raspberry Pi using Max2Play (i.e. http://max2play).
Fit the Raspberry Pi and DAC into the case using the instructions you downloaded from IQaudio earlier.
Final Connection Steps
Connect the Raspberry Pi to your hi-fi amplifier using analogue connectors (from the Pi-DAC+).
Connect to the network.
And that should be it. In the Logitech Media Server web page, or Orange Squeeze app, set the volume to 100, and use your hi-fi amplifier volume control.
Introduction
Assumptions
- You have Logitech Media Server installed and running already. If not, you can download it from My Media - Welcome to mysqueezebox.com!
- You will be connecting the Raspberry Pi to the network using cables – you can buy a wi-fi dongle, but I didn’t look into that as I prefer to use cable where possible.
- Raspberry Pi 2 Model B Desktop
- Raspberry Pi Model B+ OFFICIAL 5V 2A Multi National Power adapter
- Kingston Technology 16 GB microSDHC Class 10 Flash Card with SD card adapter
- IQaudio Pi-DAC+ Full-HD audio card
- IQaudio Pi-CASE for DAC+
- SqueezePlug & Max2Play for the Raspberry Pi from Download the Max2Play Image for Raspberry Pi and Odroid | Max2Play
- SD card formatting tool: SD Formatter for Windows Download - SD Association
Instructions
- Choose the AUDIOPLAYER tab.
- Make sure that Autostart Squeezelight is ticked.
- Click Edit Advanced Options.
- Set the Soundcard to “default - IQaudioDAC”.
- Choose the SETTINGS / REBOOT tab.
- Change the player name, if required (I changed mine to “Lounge”).
- Click Save Settings.
- Click Reboot.
